- What IBM Software does World Community Grid use?
- What is BOINC?
- How can I tell which version of the BOINC software I am using?
- How do I check if I have the latest supported version of the BOINC software?
- How do I upgrade to the latest supported version of the BOINC Software?
- How do I know that the BOINC software is running correctly?
- I have a platform that isn't supported by World Community Grid. Could I get a copy of the research application code and compile it myself?
- Will World Community Grid ever run on a game box?
- What was the difference between run time reported by the United Devices version and the BOINC version?
- How is "run time" calculated?
- How much hard drive space does the software take on my computer?
- I have been a member for a while but need to re-install the software because I have a new computer. How do I do that?
- I'm having trouble downloading the software
- If I re-install the software, will the work that I am doing be lost forever?
- Is there an easy way to install the grid agent to multiple devices or across a network?
- Does World Community Grid Software run on Windows 95?
- Does World Community Grid software run on Windows 98?
- How do I uninstall the World Community Grid Software?
- What is the BOINC Client?
- What is the BOINC Manager?
- Why does World Community Grid require version 5.4 or higher of the BOINC client?
- May I choose my member name?
- I want to contribute to one of World Community Grid's research projects. How do I register for a particular research project and start contributing?
- Do you have a startup script for the BOINC client on Linux?
- Why does the Linux version not have a screensaver?
- I have installed the recommend version of the BOINC client for Linux, but I cannot get it to run. What should I do?
- What are the recommended minimum system specifications?
- How much data will I download and upload while participating with World Community Grid?
- How do I know if my computer is running the 64-bit research application?
- How do I change my member name?
- How do I change my password?
- If I change my member name, will I lose my points?
- Why is the entry of my email address mandatory?
- How do I change my email address?
- How can I limit when the software connects to the Internet?
- How do I select a country name?
- How do I change my country name?
- What is the Verification Code and what is it used for?
- May I install as a service?
- How is my individual member rank calculated?
- The World Community Grid software on my computer is currently registered under one member name, but I would like to have it registered under a different member name. How do I change it?
- I can't run the agent all the time. Is there a way to establish a set schedule?
- I changed the schedule on the Device Profiles page but it does not seem to work?
- I have the same computer listed more than once on my device list. How can I delete the duplicate device?
- Can I set the agent not to run while I am using the compter?
- Is there a way to manage network bandwidth usage?
- How do I clear my local preferences and use the preferences set on the website?
- Is the agent continuously connected to the internet?
- How do I set the software to close the internet connection after downloading a work unit?
- Why did my firewall just log an attempt to access my computer right after I visited the World Community Grid website?
- My Internet Service Provider charges me based on the amount of bandwidth I use. How can I control how much bandwidth is used for World Community Grid?
- What ports do I have to open on my firewall to let the software connect to the server?
- What should I do if I receive a pop-up from an Anti-spy programs and/or pop-up blockers
- How will World Community Grid software affect people who use a VPN for telecommuting?
- Why does my firewall keep asking me if I want to contact World Community Grid. Isn't it safe?
- Does the World Community Grid software work with Zone Labs and how do I configure the Firewall?
- Does the World Community Grid software work with Symantec Client Firewall and how do I configure the Firewall?
- How do I determine why I cannot connect to the World Community Grid servers?
- How do I find out my proxy information?
- How do I configure the software to use a proxy?
- I entered in my proxy information but I still cannot get work. How do I get it to work?
- How do I figure out what type of proxy authentication I am using?
- Do I have to do anything on a daily basis?
- How do I check to see if I have the latest version of the World Community Grid application?
- Do I have to leave my computer on all the time for this to work? Or always be online?
- Will running the World Community Grid Software affect my regular computer use?
- How do I make the software recognize the free space on a separate drive/partition?
- Why does the software immediately download a large file as soon as it is started?
- My computer seems to be running slow since I installed the World Community Grid agent?
- How do I set up the software to automatically start on Windows?
- How do I set up my system so that the windows agent starts for several or all of the users that log in?
- How do I open the windows World Community Grid agent?
- Can I use Terminal Services with the software?
- How do I keep the software from running while my laptop is only using battery power?
- I need to completely stop the agent for a while. How do I do it?
- I have a result that the BOINC Manager reports as being "Ready to Report." What does that mean?
- The software keeps writing "Deferring communication with project for W days, X hours, Y minutes, and Z seconds". What does this mean and how do I get it to connect now?
- How do I set the software to not run while I am using the computer?
- Can you explain the screen savers?
- Will the software run faster if I do not run the screen saver?
- How do I shut down or change my screen saver?
- Do I need to use the World Community Grid screen saver in order to contribute to World Community Grid?
- How can I change the screensaver resource limits on my computer?
- I am running SETI@home on my computer? Will I be able to run both SETI@home and World Community Grid?
- What was the United Devices (UD) Agent software?
- What is BOINC?
- What operating systems are supported by World Community Grid on BOINC?
- Where may I get the BOINC client for Windows, Linux, or Mac?
- I'm using the BOINC agent, how do I choose which project my computer processes work for?
- What is my BOINC account key and where do I find it?
- I know that my computer has returned several results. Where can I check the status of those results?
- What is the address or URL to type when attaching to World Community Grid via BOINC?
- How do I set up my computer so that it will download enough work to keep my computer working for several days while I am not connected to the internet?
- Why do I have a message that says my Account Key is missing?
- How do I make World Community Grid run while my computer is on batteries?
- Does World Community Grid offer a 64 bit version of the BOINC software?
- In Advanced View, on the BOINC Manager, under Statistics, what do the figures on the y-axis represent?
- In Advanced View, on the BOINC Manager, under Transfers, why is this page blank for me?
- Is there any way we can find a history of how much data has been sent to and received from the World Community Grid server?
- In Simple View, on the BOINC Manager, do the green buttons on the project tabs change color if the processor is busy on some other task?
- What is a GPU and what does it stand for?
- What are the advantages of running World Community Grid on a computer's graphics card?
- What graphics cards are not able to participate in the Help Conquer Cancer research project?
- How do I find out what type of graphics card is installed in my computer?
- What options exist for controlling how World Community Grid uses my graphics card?
- How do I set my preferences so that World Community Grid will use my graphics card?
- How do I set my preferences so that World Community Grid will use my graphics card while I am actively using my computer?
- Will I be able to select to run work units only on my CPU, or only on my graphics card, or both?
- If you have more than one graphics card, can you limit which graphics card is used?
- If I have more than one graphics card on my computer, how do I let World Community Grid run on all of my graphics cards?
- What if my computer stutters while World Community Grid is utilizing my graphics card?
- What version of BOINC supports running research on my graphics card?
- How will statistics be updated for graphics card participation?
- Will there be a badge for graphics card participation?
- Will you make graphics card processing available for other research projects?
- Does the graphics card application include a graphic screen saver showing what is running?
World Community Grid runs on IBM WebSphere Application Server Network Deployment 6.1, IBM DB2 Enterprise 9.5 with the Performance Optimization, pure XML, and the Storage Optimization Features, and IBM WebSphere MQ 7.0.
What is BOINC?
BOINC is an open source grid software package. BOINC stands for Berkeley Open Infrastructure for Network Computing. It has been developed under a National Science Foundation grant. The software provides server side components that allow the management of a science project. It also includes client software that runs on a variety of platforms, including Linux. More information about BOINC may be found at http://boinc.berkeley.edu/.
Right click on the World Community Grid, or BOINC, icon in the bottom right corner of your display (by the date and time). Click on “About World Community Grid – BOINC Client” or “About BOINC” and the current version of the software will be displayed.
You may check which version of the software that World Community Grid is currently supporting by visiting this page: https://secure.worldcommunitygrid.org/ms/viewDownloadAgain.do . The version number is displayed below the name of the agent for each operating system. If this number is the same as the version number that you have installed then you have the latest supported version.
You may upgrade to the latest version of the World Community Grid software by visiting https://secure.worldcommunitygrid.org/ms/viewDownloadAgain.do and following the directions on that page.
One way to check is to double-click on the World Community Grid, or BOINC, icon in the system tray in the lower right of your display. An information panel will pop up that should reflect that the application is running and the panel will also display the “elapsed time” and “time remaining”.
No. The code has to remain in the control of the World Community Grid support team. Even the slightest change in the code, including using a different compiler, could render the research results useless. In addition, the license agreement that we have with the researchers for their code stipulate that only the World Community Grid support team can touch the source code. The source code usually differs slightly from potential public versions of the same code due to changes made for use with the specific grid project. Furthermore, we typically run many tests to make certain there are no problems on a given platform.
Running on game boxes requires specialized technical knowledge, plus the right kind of research project. The technical knowledge can be acquired but the research projects for game boxes must have a very small footprint. World Community Grid is investigating the feasibility of providing a client for gamers but we don't have a specific project scheduled at this time given our current priorities to launch new research projects. Going forward, we will re-evaluate the feasibility, cost and timing of making the client available to gamers and update the member community.
It is important to note, that the time reported to the server doesn't mean that the UD version was doing more work then the BOINC version. The UD version simply overcounted the actual time that was contributed to the project. In fact, the BOINC version actually contributes more time to the project because it is able to take advantage of multi-core processors or multi-processory systems. The UD version could only use one core or processor. The BOINC version will start up a science application on each core or processor and thus be able to get two or more times the work done.
"Run time" is simply a measurement of how long a volunteer's device spends running World Community Grid tasks. You accumulate run time for running tasks on your device's GPU, CPU, or both.
If you contribute GPU time, the run time is the actual elapsed time in which the World Community Grid task executes on the GPU. In other words, if the task starts at 10:15am and finishes at 10:19am, you accumulate 4 minutes of run time.
If you contribute CPU time, the picture is a bit more complicated because CPUs can prioritize different tasks and have multiple cores. Only the time a CPU spends actually executing a World Community Grid task counts toward your run time. As an example, if a quad-core computer runs a World Community Grid task on each core at 75% throttle from 10:15am to 10:19am, then each core will accumulate 3 minutes of run time (75% of 4 minutes). Across all 4 cores, the total run time would therefore be 4 x 3 minutes = 12 minutes.
The software itself will take less than 50 MB of hard drive space or your computer. The different projects that run on the World Community Grid, however, have different system requirements for running on your computer. To find out if your computer meets those requirements, go here.
For existing members, please sign in on the website, using your existing member name and password, and then click the ‘download’ button on the navigation bar or, click here.
Perhaps your Internet Explorer is configured to block installing downloads.
Within Internet Explorer, click on Tools-> Internet Options -> Security -> Custom Level -> Downloads. Check to see that File downloads are enabled. There might be other settings which need to be enabled such as the ability to execute Javascript. Please also check to see if your network requires a proxy, click here for Proxy FAQs.
No. When the BOINC version of our software is reinstalled it will stop the current workunit(s) that your computer is processing and install the new version of the BOINC software and continue to process the same workunit(s).
We have created a presentation and mass install document that describes some of the things you need to consider and steps to follow if you wish to perform a mass installation of the World Community Grid - BOINC Agent onto many machines. The presentation is available here and the document is available here.
Windows 95 is no longer supported by Microsoft, therefore we do not offer an installer for that platform.
Effective August 1, 2008, the World Community Grid technical staff will no longer provide support for Windows 98. We are taking this action because less than 0.03% of all computers on World Community Grid are running on Windows 98 and we feel that our resources need to be focused on supporting existing and new research projects.
If you are running Windows 98 as your operating system, you will still be able to run World Community Grid and contribute to humanitarian research. However, if you have a problem, you should not expect to receive a response to your Windows 98 question from the "Contact Us" mailbox. Assistance in the forums may be available as long as other members continue to respond to Windows 98 questions.
All of the current research projects were tested for Windows 98. Therefore Windows 98 users should be able to continue to run on that platform depending on their specific configuration of software. This means that Windows 98 users should be able to participate in World Community Grid research for at least one more year.
Going forward, none of the new research projects will be certified for Windows 98.
Right click on the World Community Grid icon in the lower right corner of your screen and select "Exit". This will stop the agent. Then use your Add/Remove programs feature to remove the World Community Grid software. If that does not work, use the task manager to stop the processes starting with WCGrid. Then you should be able to delete the C:\Program Files\WorldCommunityGrid directory and its contents. After that remove the corresponding start menu items.
The BOINC client is a command line application that runs on Linux. This application contains the functions necessary to connect your Linux computer to World Community Grid. These functions include the following:
- Attach your computer to World Community Grid (use: http://www.worldcommunitygrid.org)
- Download work from the World Community Grid servers
- Return completed results to the World Community Grid servers
- Run the science application according to the preferences of the member
The BOINC manager is a graphic user interface that provides the ability to control a BOINC client and all of its functions. The manager can connect to BOINC clients running on the same or different computers. There is a version of the BOINC manager available for both Linux and Windows. This means that you can run the BOINC manager on your windows computer and connect to BOINC clients running on your Linux servers. Much more information about the BOINC manager is available at: http://boinc.berkeley.edu/manager.php
World Community Grid requires version 5.4 of the BOINC client because we have configured the system to communicate with the BOINC client over SSL. Only version 5.4 and higher of the BOINC client are able to utilize SSL. SSL is a technology that encrypts all communication between the client and the server. This provides greater security for our members.
If you attempt to use an older version of the BOINC client, then you will see an error in the BOINC client log file.
Yes. You may choose any member name that is not already in use. You can change your member name at any time (but, of course, only to another member name that is not in use). If you do change your member name, your previous member name will become available to other members.
Members only need to register and attach once to World Community Grid in order to contribute to any, or all, of our research projects. In order to contribute, please take the following steps:
- Register with World Community Grid
- Select which of our research projects you wish to contribute to:
- The registration process gives you a list of research projects to choose from
- If you are already registered, you may change which projects you contribute to on your My Projects page
- If you do not already have BOINC installed download and install the software
- If you already have a version of BOINC installed more recent than version 5.4, then you may participate in World Community Grid using your existing BOINC software. Just attach to World Community Grid using the url: http://www.worldcommunitygrid.org and using the member name and password you created in step 1 above.
There are two common ways to have BOINC automatically start on a Linux system. The first will start BOINC when you log in to your Linux system. This involves placing code into your shell resource file (such as .bashrc). The second will start BOINC when the system is started. You can read more about this at the following sites: http://www.spy-hill.net/~myers/help/boinc/unix.html#start and
http://boinc.berkeley.edu/autostart_dennett.txt
A screensaver has not been developed by the BOINC development team at this time.
Which version of the Linux client you should use depends highly on the libraries that you have installed on your machine. The recommended version is what you should try first. However, if this does not work, then you should try one of the 'compatible' builds. You may find these here. The compatible builds are command line only.
In order to participate in World Community Grid, you will need to have at least the following:
- The ability to display graphics (if you wish to see the graphics)
- An Internet connection
In addition, each research project has its own requirement for memory and disk space. These are as follows:
| Research Project |
Memory Available |
Disk Space |
Operating Systems |
| Say No to Schistosoma |
100 MB |
50 MB |
Windows1,5, Mac2, Linux3,5 |
| GO Fight Against Malaria |
250 MB |
50 MB |
Windows1,5, Mac2,5, Linux3,5 |
| Drug Search for Leishmaniasis |
250 MB |
50 MB |
| Computing for Clean Water |
400 MB |
100 MB |
Windows1,5, Mac5, Linux3,5 |
| The Clean Energy Project - Phase 2 |
1,024 MB |
2,048 MB |
Windows1, Mac2, Linux3,4 |
| Help Fight Childhood Cancer |
250 MB |
100 MB |
Windows1, Mac, Linux3 |
| Human Proteome Folding - Phase 2 |
250 MB |
100 MB |
Windows1, Mac2, Linux3 |
| FightAIDS@Home |
250 MB |
100 MB |
1. World Community Grid supports the following Windows platforms: Windows XP, Vista, 7, Server 2003, Server 2008
2. For these projects, only Mac computers using Intel processors are supported
3. Only Linux on x86 and x86-64 is supported
4. Users who choose to run this project are encouraged to set the 'Leave applications in memory while suspended' option in their device profile
5. 64 bit application available
6. GPU application available, OpenCL 1.1
The amount of data that you transfer depends upon how your processing preferences are set to run, how powerful your computer is and how often your computer is on. It also varies based upon which research projects you run on your computer. An average computer contributing to World Community Grid returns about 2 results per day.
Each of the research projects at World Community Grid uses a different application, input files and output files. As a result, the size used for each of these varies by project. This is outlined on the chart below. Please note that the data is compressed during transfer and is decompressed after it has been downloaded. As a result it will occupy more space on disk then the numbers shown below.
| Research Project |
One-Time Download |
Per Workunit Download |
Per Workunit Upload |
| Computing for Sustainable Water |
20 MB |
0.2 MB |
0.2 MB |
2 MB |
0.2 MB |
0.1 MB |
2 MB |
0.2 MB |
0.1 MB |
2 MB |
0.2 MB |
0.1 MB |
10 MB |
0.001 MB |
0.5 MB |
200 MB |
0.1 MB |
20 - 80 MB |
| Discovering Dengue Drugs - Together - Phase 2 |
10 MB |
1-20 MB |
1 MB |
| Help Cure Muscular Dystrophy - Phase 2 |
0.7 MB |
0.1 MB |
0.2 MB |
1.0 MB |
0.1 MB |
0.1 MB |
| Help Conquer Cancer |
1.0 MB |
0.1 MB |
0.1 MB |
12.0 MB |
1.5 MB |
0.1 MB |
| FightAIDS@Home |
1.5 MB |
0.1 MB |
0.1 MB |
On a Windows machine, you can use the Windows task manager to view the process name. 64-bit research applications will end with "windows_intelx86_64", while 32-bit applications will end with "windows_intelx86"
On a Linux machine, you can find the PID of the research application (which will start with the name "wcg") and then execute the command "file -L /proc/PID/exe"
To change your member name, take the following steps:
- Go to the World Community Grid home page or select My Grid from the upper navigation bar.
- Sign in using your current member name and password.
- From the My Grid / My Statistics page, select My Profile from the menu on the left.
- On the My Profile page, change the Member Name.
- Press Save.
To change your password, take the following steps:
- Go to the World Community Grid home page.
- Sign In using your current member name and password.
- From the My Grid / My Statistics page, select Sign In Manager from the menu on the left.
- Enter your new password twice.
- Press save.
No, changing your member name will not affect your points or any other contribution that you've made to World Community Grid.
The member name recovery feature uses your email address to identify and send your member name.
To change your email address, take the following steps:
- On the My Profile page, change the E-mail Address field.
- Press Save.
There are two ways to do this:
- On your machine, go to [Start] [Settings] [Control Panel] and double click on "Internet Options." Click on the [Connections] tab. There will be 3 radial buttons towards the bottom of the window; set them to "Never dial a connection." Because the software operates like any other Windows application and simply requests an Internet connection that Windows then provides, doing this will force Windows to ignore requests for an Internet connection. You must therefore manually initiate a connection to your ISP to connect to the Internet.
- Enter the
Device Profiles section of the site. Next click on the default profile and follow the instructions to change the execution time for your computer(s) and save. This will change the connection times for all computers under your member name.
To change the connection times for a particular computer under your member name. Double click on the World Community Grid, or BOINC, icon in your system tray. Select Preferences and designate your preferred connections times and select “save”.
To enter your country name, take the following steps:
- On the My Profile page, select the country code of your choice.
- Press Save.
To change your country name, take the following steps:
- On the My Profile page, select the country of your choice.
- Press Save.
The Verification Code is a private, personal code that you can use to verify your team membership and team stats. There are teams that provide incentives and/or rewards to members for being a part of their team. World Community Grid is providing the Verification Code as a way for these teams to verify their members' statistics and team membership without requiring members to give the team their password.
Note that your Verification Code will change if you change your member name and/or password. If your team is relying on your verification code to verify your membership and statistics, be sure they have your current Verification Code.
To verify the team membership and statistics for a member, use the URL:
http://www.worldcommunitygrid.org/verifyMember.do?name=MEMBERNAME&code=VERIFICATIONCODE
You will get a response in XML containing the membership information for that member. If there is an error, it will be reported back in the XML response.
Yes. To install as a service, simply select that option during the installation process. A graphic of the service install option is reflected here.
A member may see their individual stats on their My Grid page for run time, points, and results returned. Your individual rank is based on the total number of members that have returned a result. You may see how many members there currently are on the Global Statistics page.
If you have already created the member name you want to use then please continue to Step 1 below.
Otherwise, go to http://www.worldcommunitygrid.org/reg/viewRegister.do and register your desired member name. You do not need to download the software again.
Once you have the new member name, please perform the following steps to change the registration:
Steps:
- Open the World Community Grid – BOINC software by double left mouse clicking on the World Community Grid icon in your system tray at the bottom right hand side of your window.
- Once it is opened, if you see the ‘Simple View’, then click on the text that says ‘Advanced View’.
- Select the ‘Projects’ tab and select World Community Grid. Then click on the button that says ‘Detach’.
- Now go to the menu items at the top of your screen and select advanced and select ‘Tools’ and then ‘Attach to project…’. This will open a dialogue box. If 'Attach to project…' is grayed out, see the instructions below.
- In the dialogue box, click ‘Next’. On the next screen, scroll through the list of BOINC projects and select World Community Grid and then click the ‘Next’ button.
- On the next screen, enter the member name and password for the user that you want to register this device under.
Congratulations! You are now attached under the new member name.
Enabling 'Attach to project…': If in step 4 the option ‘Attach to project…’ is grayed out and you are unable to select it, then you need to open the file C:\Program Files\BOINC\cc_config.xml using an application such as Notepad. Once you open this file you will see a line that looks like:
<disallow_attach>1</disallow_attach>
change this line so that it looks like:
<disallow_attach>0</disallow_attach>
Now save the file. Go ahead and close the World Community Grid – BOINC software by selecting File -> Exit. You can start it again by going to Start -> Programs -> World Community Grid – BOINC Agent -> World Community Grid – BOINC Manager. You should now be able to complete step 4 above. If you experience any problems please visit our forums or utilize the “contact us” feature at the bottom of most pages of our website.
Yes, you may customize when the agent runs. This is done by updating the device profile associated with the device where the agent is running. You can update the device profile by visiting the Device Manager. Once there, click on the device profile for the device whose schedule you want to change. Once on the Device Profile page, you can set a customized schedule for each day that you need one. When finished, press save. After you press save, the schedule will go into effect the next time your grid agent communicates with the grid servers. When establishing the customized schedule, the drop-down for Hard drive space may be ignored.
If needed, you can create additional device profiles by visiting the Device Profiles screen. This screen has an option that allows you to create new profiles.
Changing your profile on the website will change your preferences for all of the computers you have under your member name. If you need to have different preferences for different computers you may set preferences for each computer by double clicking on the World Community Grid or BOINC icon in your system tray and selecting Advanced View. From the menu at the top of your screen, select: Advanced>Preferences and then set your preferences for that specific computer. Remember to select “OK” after you have set your preferences. Please note: Local preferences set at your computer will override preference settings on the website
This schedule change affects the grid agent running on your computer. For security reasons, no information is pushed to the grid agent while it is running on your computer. Only when your grid agent communicates with the grid servers does anything change with the grid agent. When your grid agent finishes its current unit of work, it will initiate communications with the grid server, and then your new schedule will take effect.
To update your preferences immediately, double click on the World Community Grid, or BOINC icon, in your system tray and select Advanced View. Then select the “projects” tab and click on World Community Grid. From the left hand menu, select “update”. This will retrieve your preferences. Please note: Local preferences set at your computer will override preference settings on the website.
The World Community Grid agent registers itself as a new device each time the software is installed. The agent does not know whether it is being installed on a computer where it was previously installed or whether it is a new computer altogether. If a member installs the software more than once on the same computer, then they are likely to see two devices with the same listed on the website. At this time it is not possible to delete the additional devices listed on the website.
The Device Manager page and the Device Statistics page shows by default all of your devices that were registered within the past 7 days or that have returned a result within the past 14 days. Unused devices do not appear on this page when these time periods have passed.
Yes, you may customize the agent not to run when the computer is in use. This is done by updating the device profile associated with the device where the agent is running. You can update the device profile by visiting the Device Manager. Once there, click on the device profile for the device whose schedule you want to change. Once on the Device Profile page, select 'Custom Profile'. Under 'Advanced Options' 'Processor Usage' set 'Do work while computer is in use' to 'No' and 'Do work only after computer is idle for' to the number of minutes you want the agent to delay. When finished, press save. After you press save, the schedule will go into effect the next time your grid agent communicates with the grid servers.
You can control the maximum rate at which BOINC will transfer data. You can set this on our website through your device profile. Your device profiles may be changed here.
After logging in, select the profile that you wish to customize. (Usually the 'Default' profile) After selecting the profile you wish to change, select 'Custom Profile'. You will be presented with many option, which include a category called 'Network Usage'. You may change your bandwith use there. Remember to save your changes when you are finished customizing your profile.
To clear your local preferences, you will need to pull up your preferences. To do this, double click on the World Community Grid, or BOINC icon, in your system tray and select Advanced View. Then in the top menu, pull down the "Advanced" menu and select "Preferences". Then click the "Clear" button. After you have done this, press "OK" to close the preferences window. Once this is done, select the "Projects" tab and click on World Community Grid. From the left hand menu, select "Update". This will retrieve the preferences from the website and clear your local preferences.
No. The agent connects to the internet when it finishes a work unit to upload the results as well as download a new work unit. This should take 2-3 minutes on a broadband connection and 10-15 minutes with a modem.
The software does not attempt to control your Internet connection. Establishing and closing the connection is done by the operating system (Windows). If your Internet connection is staying active for an excessive period of time, go to [Start][Settings][Control Panel] and double click on "Internet Options." Click on the [Connections] tab. Highlight the dialup connection being used when the software connects to the Internet and click on [Settings]. Click on [Advanced] and check the "Disconnect when connection may no longer be needed" box.
Some users have noticed, via their software firewall, that trace-route scans apparently coming from IBM domains occur after communicating with the World Community Grid server. These are in fact normal and not someone trying to break into your machine. These are used to measure which of several paths through the Internet give the best communication performance to your machine. The servers are located in a massive hosting center, which regularly optimizes traffic between users and the servers by shifting communications among several Internet providers, depending on the destination and trace-route measurements.
The most recent version of the World Community Grid/BOINC Software allows you to control how much data is transferred between your computer and our servers. You can set this by doing the following:
Go to 'My Grid'.
Go to 'Device Manager'.
Look for the device that you want to limit, and then click on the selected profile for that device.
On the screen that is presented, select 'Custom Profile'.
Scroll down to the section that says 'Network Usage' and find the item labeled: Transfer at most: X Mbytes every Y days.
You can use this to say that you only want World Community Grid to use at most 500MBytes of bandwidth every 7 days (which would then limit you to 2GBytes/month). Or you could put 1024MBytes every 31 days which would limit you to 1GB per month.
Open ports 80, 443 and 31416 outbound.
There are normally no pop-ups to block. Any anti-spy program which acts like an outgoing firewall would have to be configured in a manner similar to the fiewall settings
The software will not have any effect. The software communicates without problems with, or without, VPN Client Software. Our server site is an external internet address. The bandwidth usage is minimal and equivalent to visiting a few web pages once a week or every few days on more powerful computers.
Firewalls are not familiar with World Community Grid. Even though World Community Grid is safe, firewalls are designed to ask you to make the decision. Most firewalls will allow you to set your firewall to allow communications with World Community Grid BOINC client. Although firewalls differ, you should be able to click on your firewall icon in your system tray and set permissions to allow communications.
Also please note, when firewall software is updated by the manufacturer, you may be required to update your permissions for World Community Grid BOINC client communications. The same is true if the World Community Grid software is updated.
If you have a Zone Labs firewall, just click on "Yes" to continue. You may save yourself some time in the future by optionally check-marking the message "Always allow this program to access the internet" and/or check-marking the message "Remember this answer the next time I use this program."
If you have Symantec Client Firewall, you can select "Permit Always" if/when an alert comes up so that you won't be prompted again when the World Community Grid BOINC client tries to communicate with the World Community Grid servers.
Yes. The software initiates only outgoing connections on ports 80, 443 and 31416 to www.worldcommunitygrid.org and secure.worldcommunitygrid.org. This could be preconfigured as a safe zone. Alternatively, the boinc.exe and boincmgr.exe executables in the BOINC install directory could be configured to be permitted to perform this communication. However, if and when we update the agent software, it could need to be configured again.
- Double click on the Zone Labs icon in the system tray at the lower right.
- Click on "Firewall" at the left.
- Click on the "Zones" folder tab in the upper right area.
- Click on "Add >>" in the lower right.
- Choose "Host/Site".
- Select "Trusted" for the Zone field.
- Enter "secure.worldcommunitygrid.org" for the Host Name field.
- Enter "World Community Grid Secure" for the Description field.
- Click the Lookup button.
- Click OK.
- Repeat the adding of a "Host/Site" using "www.worldcommunitygrid.org" for the Host Name, and "World Community Grid WWW" for the Description.
- Click Apply in the lower right.
- Then close the window with the X in the upper right.
Configuring the Symantec Client Firewall:
- Double click on the Symantec Client Firewall icon in the system tray at the lower right.
- With "Status & Settings" selected, click on "Client Firewall".
- Click on the Configure button.
- Click on the Programs tab.
- Under "Manual Program Control", scroll down to "BOINC client".
- Click on the arrow next to whatever is currently displayed under "Internet Access" and select Permit All.
- Repeat the previous step, this time for "World Community Grid" under the Programs list.
- Click the OK button, and close the Symantec Client Firewall using the X in the upper right.
If "BOINC Client" or "World Community Grid" are not listed as a Program under "Manual Program Control" you can add it by clicking the Add button, and adding 2 programs. Both programs are in the location where the World Community Grid BOINC client was installed (usually C:\Program Files\BOINC). First select "boinc.exe". Then click Add again and pick "boincmgr.exe".
To determine why you are not receiving or sending workunits to World Community Grid, make sure you are using the latest version of the BOINC software and check your client firewall to ensure that the 'BOINC client' software reflects "permit all" or similar verbiage that your firewall software uses to reflect an approved program.
If you are on the latest version and your firewall is set to allow the BOINC client to communicate, then please double click on the World Community Grid or BOINC icon in your system tray. Select messages and see if you have any entries like the following:
09/10/2007 14.30.14|World Community Grid|[file_xfer] Started upload of file li349_00025_8_0
09/10/2007 14.30.15|World Community Grid|[file_xfer] Temporarily failed upload of li349_00025_8_0: http error
or
05/03/2008 11.55.14|World Community Grid|Sending scheduler request: Project initialization. Requesting 1 seconds of work, reporting 0 completed tasks
05/03/2008 11.55.19|World Community Grid|Scheduler request failed: Failure when receiving data from the peer
If you do, then you may need to set your proxy. Here is the FAQ that describes how to set your proxy. If you do not know your proxy information here is the FAQ that will help you obtain your proxy information.
Your proxy settings are available in your Web browser. In Internet Explorer, these are under [Tools][Internet Options...][Connections] then choose either [LAN Settings] or [Settings] for your dial-up options. If "Use Proxy" is checked, click on the [Advanced...] button to see your proxy settings.
You will need to take these settings and enter into the BOINC version of the World Community Grid software. Instructions for doing this are found in this FAQ
The software can be configured to use a proxy in the following way:
- Double click on the World Community Grid or BOINC icon in the system tray
- When it opens, if you see some text that says select 'Advanced View', then click on it
- From the options on the top of the screen select 'Advanced' -> 'Options'
The dialogue that opens has tabs that allow you to enter in your HTTP or SOCKS proxy information.
If after you enter your proxy information and you still see messages such as those displayed in the FAQ "How do I determine why I cannot connect to the World Community Grid servers?" above, then you will need to take the following additional steps:
Make sure you are on the latest version of the World Community Grid agent by following the directions in this FAQ.
If this doesn't resolve the issue, then you will need to determine what type of proxy authentication you are using. To determine your proxy authentication please refer to this FAQ.
Once you have determined your proxy authentication, open windows explorer and go to C:\Program Files\BOINC . In this directory you will see a file called cc_config.xml . Assuming you are using windows, right mouse click on the this file and select 'Open With' and select 'Notepad'.
This will open a new window that will be populated with the contents of your cc_config.xml file. It will look something like the following:
<cc_config>
<log_flags>
<file_xfer_debug>1</file_xfer_debug>
<http_debug>1</http_debug>
<http_xfer_debug>1</http_xfer_debug>
<proxy_debug>1</proxy_debug>
</log_flags>
</cc_config>
You want to replace this with additional settings for your 'ntlm' or 'basic' proxy.
<cc_config>
<log_flags>
</log_flags>
<options>
<force_auth>xxxxx</force_auth>
</options>
</cc_config>
Replace the above 'xxxxx' with either ntlm, basic or gss-negotiate based on what type of authentication you are using and save the file.
In order to make the software re-read the file do the following:
- Double click on the World Community Grid icon in the system tray
- When it opens, if you see some text that says 'Advanced View', then click on it
- From the options on the top of the screen select 'Advanced' -> 'Read config file'
Finally, in order to check that you are able to download work, please do the following:
- Select the 'projects' tab
- Select World Community Grid from the list
- Click on the 'Update' button.
- Go to the messages tab
If all is working correctly, then you will see that you are downloading work and you will start processing it. If this has not helped you, then you can seek further help in the forums or by contacting us through the contact us feature on our website.
First, make sure you are using the latest version of the software. Instructions on how to do this are available in this FAQ
Second, there are some types of proxies that need additional settings to work with World Community Grid. The first thing you need to do is to enable some additional logging for the client. You can do this by downloading this file and placing it into your BOINC installation directory (on Windows this is usually C:\Program Files\BOINC). You now need to double click on the World Community Grid icon in your system tray (bottom right hand corner of your computer screen, by the date and time), select "Advanced View", then on the menu across the top of page select "Advanced", and then "Read config". Now more information will be logged.
In the Advanced View of the agent, go to the 'Projects' tab, click on World Community Grid, and then select 'update'. Next go to the "Messages" tab. You will see messages going by. The critical one to look for is the line that includes "Proxy-Authenticate" like the ones shown below. There will be one or more of these in a row. You are interested in the first one.
07/04/2008 18:18:09||[http_debug] [ID#0] Received header from server: Proxy-Authenticate: Negotiate
03/25/2008 12:24:54||[http_debug] [ID#0] Received header from server: Proxy-Authenticate: NTLM
03/25/2008 12.24.54||[http_debug] [ID#0] Received header from server: Proxy-Authenticate: Basic realm="realmname"
Take note of the following:
- If the first line contains "Negotiate" then you are using gss-negotiate authentication
- If the first line contains "NTLM" then you are using ntlm authentication
- If the first line contains "Basic" then you are using basic authentication
No. Once you have downloaded and installed the agent, there's nothing that you have to do. The agent will run on your computer when it determines that there are unused cycles available. When it finishes with a calculation, it will send the completed work to the grid server and then ask the grid server for more work.
You may check what version of the World Community Grid - BOINC agent you have by right clicking on the World Community Grid, or BOINC, logo in your system tray and selecting the item that says 'About World Community Grid - BOINC Agent' (in some cases it will say 'About BOINC'). This will display a window. The version you have installed is shown next to the text on the window that says 'Version: '
You can check which version of the World Community Grid - BOINC Agent that World Community Grid has currently released by visiting this page: https://secure.worldcommunitygrid.org/ms/viewDownloadAgain.do . The version number is displayed below the name of the agent for each operating system. If this number is the same as the version number that you have installed then you have the latest version.
The software can run only when your computer is on. The software doesn't need to be connected to the Internet to work its task, but once finished, it needs to reconnect to return data and to get a new task to work on. We do not ask our members to change their normal computing schedule.
No. Configured correctly, the software will never interfere with your ability to use your own computer. Most computers never use all of their resources and it is estimated that up to 90% of the processing power of an individual computer goes unused. The World Community Grid distributed computing model is based on the ability to utilize this "idle" capacity from individual computers.
The software will only recognize the free space on the partition on which it is installed. If you have a drive/partition with more free space that you want the software to use, you must install the software to that drive/partition.
The task downloaded by your software is comparing small pieces of data against a larger database. In order to make this task effective and to maximize the potential of your machine, it is necessary to keep some data locally. For the time being, this is a one-time download. Subsequent tasks may or may not have an up-front download depending upon the nature of the computational problem.
If your computer seems to run slower when running the agent, then you may have relatively little memory in your system. Using 100% CPU alone will not slow things down because the agent runs at lowest priority so that it yields to any other work. Otherwise, it consumes the unused CPU which makes the total go to 100%. However, if your system has relatively little real memory (usually about 512 meg or less) and you are running other memory hungry applications, then there might be disk paging delays. To solve the problem, you could set your agent to run in screen saver mode only. Then, while you are actively using the machine, the agent will stay out of the way.
If you find that the software is no longer starting up automatically when you start your computer, then please follow the steps below to set it up to automatically start up again:
- Go to C:\Program Files\BOINC using the Windows Explorer
- Right mouse click on the file 'boincmgr.exe' and select 'Create Short Cut'
- A new file is created called 'Shortcut to boincmgr.exe'. Right mouse click on this file and select 'Cut'
- Next go to C:\Documents and Settings\All Users\Start Menu\Programs\Startup
- In the folder, right mouse click on some empty space and select 'Paste'. The short cut will appear.
The next time you restart your computer, the software will be started automatically.
You can place the World Community Grid icon into each of the user's startup folders (in Start Menu->Programs->Startup), which will make the agent start whenever those particular users log on. You can also place it in the startup folder for "All users" which should make it run for everyone. One way to get to these folders is via: My Computer -> Local disk C: -> Documents and Settings -> All Users -> Start Menu -> Programs -> Startup, for example.
On your windows desktop, typically in the bottom right of your screen, is the system tray. It looks similar to this in Windows XP:
In the system tray you should have an icon that looks like this: Double left mouse click on it and you will see the agent.
Multiple users running the software via Terminal Services is not a supported configuration at this time. Allowing multiple users to run from the same install image can cause problems, whether this is via Terminal Services or running from a shared network directory. The supported configuration is one instance of the software per machine. The software will prevent multiple instances of itself from being launched.
The software is configured so that it will not run while your laptop is on battery power.
If you need to stop your agent for a little while, use the snooze icon (moon shape) on the agent. You can change the default on the preferences page (check icon). If you are running a memory intensive application for a longer period of time and notice slight delays, you might want to set the agent to run only as a screen saver. Go to the preferences window (the one with the check icon) and select "Run only as Screen Saver" and then click on "Apply". This will make the agent only run when your pc is in screen saver mode. Finally, you can completely stop the agent by first minimizing its window, right clicking on its icon in the tray at the lower right, and selecting "Exit". This causes the agent to stop until the next reboot. You can also restart it at any time using the Start menu.
The BOINC client returns a completed work unit to the server in a two-step process. The first step is the uploading of the calculated data (called the result file). The second step is for the BOINC client to contact the server and report that the work unit is complete and to provide additional information, including how long it took to process the work unit.
The BOINC Manager will report a work units status as 'Uploading' as soon as the work unit has completed. Once the file has been uploaded, then the BOINC Manager will report the work unit as 'Ready to Report'.
More information about work unit status messages may be found here.
This message appears when the software has experienced a problem connecting to the server. This may be because of some problem on your local computer or because World Community Grid's servers are temporarily unavailable due to maintenance or updates.
The software will delay the attempt to reconnect because during the time that the servers are unavailable, more and more local computers will try to connect to the servers. Once the servers became available the servers could become overwhelmed if all of the local computers attempted to contact them at once. This mechanism reduces the chances of the servers being overwhelmed.
To change your preferences for all computers under your member name, sign on to our website and go to your “My Grid” page. Select “Device Manager”, then “Device Profiles" from the left hand Navigation. Click the Profile Name that you want to update and select custom profile. Under "Advanced Options" change your settings as follows:
- Do work while computer is in use? No
- Do work only after computer is idle for: XX = Equals the desired number of minutes
- Select save
The new settings will take effect when the software next communicates with the servers.
You may find an explanation of the various project screen savers under the specific research project name found in the “Overview” section of our Help facility
Yes. The screen savers divert your computer resources to motion and graphic processing. This is not just for the World Community Grid's screen savers, but for most screen savers.
Click on [Start] [Settings] [Control Panel], and then double click on "Display." Click on [Screen Saver]. Use the drop down menu to either change the screen saver or shut it off by selecting "None."
No. You may utilize any screen saver of your choice and still be able to contribute to World Community Grid. World Community Grid runs at the lowest priority and will yield to any other application but will utilize any unused computer cycles available. (Note: World Community Grid screen savers are designed to work with the science applications at lowest priority with resource limitations. This minimizes the impact on your computer's resources. Other screen savers may not be designed to run at lowest priority with resource limitation.)
You will need to modify your Device Profile on the website. On your My Grid page, select Device Manager, and then Device Profiles. Under Profile Name, select which Profile you would like to change (Default, School, Home, etc.). Then select the Custom Profile radio button. Under Advanced Options, scroll down to the Graphics section. The defaults are set to 7 frames per second and 5% cpu usage. If you would like the screensavers to refresh quicker, change the frames per second to 30. If the screensavers are taking up too much CPU power, decrease the percentage from 5% down to 2% to keep the screen saver usage to a minimum. Click Save at the bottom of the page to save your changes. The next time your computer communicates with our website, the preferences will be updated.
Yes and no. Any non-grid.org agent, such as SETI@home, will be able to continue to run on your computer after you download and install the World Community Grid agent.
However, while you can run both clients at the same time, SETI@home runs at a higher priority than the World Community Grid agent, so SETI@home will receive all the extra available CPU cycles and will starve the World Community Grid agent. Because of this, you should only run one or the other at any given time.
The UD Agent software was the software that was initially used by World Community Grid to distribute and run research on members' computers. It has been replaced by the BOINC software. The BOINC Migration Announcement may be found here.
What is BOINC?
BOINC stands for Berkeley Open Infrastructure for Network Computing. It is a software platform for distributed computing using volunteer computer resources. Much more information about BOINC can be found at the BOINC website: http://boinc.berkeley.edu
World Community Grid currently supports the operating systems listed in our System Requirements FAQ, which you can find here. Although they are not supported by World Community Grid, some of our members have had success using other platforms found here.
If you are a new member and do not currently have a World Community Grid member name, you may register and download the BOINC client here.
If you are currently a World Community Grid member and want to download the BOINC client to a new, or additional computer(s), you may download the BOINC client client here.
You may select which projects you participate in using the My Projects page. This will set the projects you participate in for all of your devices. To set projects to run on certain device profiles, go to the Device Profiles page. From there you can set each of your BOINC device profiles to run a different set of projects.
The BOINC Account key is a unique identifier that is used by the BOINC client and the BOINC server to uniquely identify you, and your computers, registered under your member name. You may find your BOINC account key on your My Profile page.
You may check your World Community Grid results by logging into our website using your existing member name. On the left hand menu on your "My Grid" page, select "Results Status". You may access this page here. A detailed description of the various statistics may be found here.
Use http://www.worldcommunitygrid.org to attach to World Community Grid via BOINC.
You can set up the BOINC agent so that it will keep a cache of workunits to keep your computer busy even if you are disconnected from the internet. You can do this on the website by going to My Grid -> Device Manager. This screen will show you a list of your active computers. Associated with each computer is a device profile. Click on the device profile associated with the computer you want to cache workunits on. On this next screen select 'Custom Profile' and then find the field labeled 'Connect to network about every X days' Change X so it is slightly longer then the time you think your computer will not be connected to the network.
Please do not use values longer then 4 days, as the scheduling algorithm in the client may prevent you from getting as much work as you would like.
When you installed our application, the Account Key was not properly assigned. Please take the following action:
- double left click on the World Community Grid or BOINC icon in your system tray
- click on "advanced view" (if not already in advanced view)
- click on your "projects" tab
- click on World Community Grid and then on the left hand menu select "detach"
- now, go to menu's at the top of your screen and select Tools -> Attach to Project
- this will bring up a panel that asks you to enter in a project URL. Please use:
Then you will be asked for your member name and password. Once you complete these steps, your account key should be properly assigned.
You may change your preferences to allow World Community Grid to run while you are on battery power as follows:
- To change your preferences for all computers under your member name, sign on to our website and go to your “My Grid” page. Select “Device Manager”, then “Device Profiles from the left hand Navigation. Click the Profile Name that you want to alter and select “Custom Profile”. Under “Processor Usage” change your setting to reflect: “Do work while computer is running on batteries: Yes” and select “save”. The new settings will take effect when the agent software next communicates with the servers.
- To change the preferences for a particular computer under your member name. Double left click on the World Community Grid, or BOINC, icon in the system tray of the appropriate computer. Select Preferences from Simple View. Then check “I want to customize my preferences for this computer only” and then click “Do work while on battery” and “save”. The setting changes made here take effect immediately and override those in the device profile above.
No. The science applications are only available in 32 bit so everything we do, including validation, is offered in 32 bit. Going forward, we will re-evaluate the feasibility, cost and timing of offering a 64 bit version of the BOINC software to the member community.
The figures represent BOINC credits. A BOINC credit is equal to 7 Points on our website. Additional information on the BOINC Manager - Advanced view may be found here.
This tab shows pending or in progress transfers only. Once a transfer is complete it is removed from the view.
No. At this time there is no way to see how much data has been actually transferred by a given client.
The presence of the green button indicates that the task is currently running. If it is not running, then the green button is not present. Additional information on the BOINC Manager - Simple view may be found here.
GPU is an abbreviation for graphics processing unit. Graphics processing unit is another name for the graphics card inside your computer.
A few years ago, the graphics card manufacturers realized that graphics cards could perform certain types of computations significantly faster than the central processing unit (CPU) inside a computer. As a result, they extended the capabilities of some graphics cards so that they could run tasks that were written in a specialized development language. As a result, applications that are modified to use this specialized development language and can leverage the graphics cards specialized capability appropriately, can potentially run many times faster on the graphics card then on the CPU.
The advantage of running World Community Grid on your computer's graphic card is the fact that you can expect to complete more research then you would be able to complete using just your CPU.
However, graphics card processing is different than CPU processing in that graphics card processing does not have the same sophisticated operating system capabilities that allow us to make sure that running the research does not interfere with your use of your computer. Many graphics cards can run World Community Grid without any interference, however, some will cause your computer to be slow in responding to you.
Certain graphics cards do not have the hardware instructions or are too slow to run this project effectively. As a result , some cards will be excluded from participation.
The cards that will be excluded listed below. We will periodically review the system for additional cards that should be added to this list.
AMD/ATI:
- ATI Radeon HD 2300/2400/3200 (RV610)
- ATI Radeon HD 2600 (RV630)
- ATI Radeon HD 3800 (RV670)
- ATI Radeon HD 4350/4550 (R710)
- ATI Radeon HD 4600 series (R730)
- ATI Radeon HD 4700/4800 (RV740/RV770)
NVIDIA:
- GeForce 210
- GeForce 310
- GeForce 310M
- GeForce 315
- GeForce 315M
- GeForce 405
- GeForce 410M
- GeForce 610M
- GeForce 8200
- GeForce 8400
- GeForce 8400 GS
- GeForce 8500 GT
- GeForce 8600 GS
- GeForce 8600M GS
- GeForce 8600 GT
- GeForce 8600M GT
- GeForce 8600 GTS
- GeForce 8700M GT
- GeForce 8800 GT
- GeForce 8800 GTS 512
- GeForce 8800M GTS
- GeForce 9200
- GeForce 9300 GE
- GeForce 9300M GS
- GeForce 9400 GT
- GeForce 9500 GS
- GeForce 9500 GT
- GeForce 9600 GS
- GeForce 9600M GT
- GeForce 9600 GSO
- GeForce 9600 GSO 512
- GeForce 9600 GT
- GeForce 9800 GT
- GeForce 9800 GTX+
- GeForce 9800 GTX/9800 GTX+
- GeForce 9800 S
- GeForce G102M
- GeForce G105M
- GeForce G210
- GeForce GT 120
- GeForce GT 130
- GeForce GT 130M
- GeForce GT 220
- GeForce GT 220M
- GeForce GT 230
- GeForce GT 230M
- GeForce GT 325M
- GeForce GT 330
- GeForce GT 330M
- GeForce GT 420
- GeForce GT 510
- GeForce GT 520
- GeForce GT 520M
- GeForce GT 610
- GeForce GT 630
- GeForce GTS 240
- GeForce GTS 250
- GeForce GTX 260M
- GeForce GTX 280M
- GeForce GTX 660M
- NVS 300
- NVS 3100M
- NVS 4200M
- NVS 5100M
- Quadro 400
- Quadro FX 1600M
- Quadro FX 1700
- Quadro FX 1800
- Quadro FX 2700M
- Quadro FX 2800M
- Quadro FX 3700
- Quadro FX 380
- Quadro FX 570
- Quadro FX 570M
- Quadro FX 580
- Quadro FX 770M
- Quadro FX 880M
- Quadro NVS 160M
- Quadro NVS 290
If you have a computer with a Windows operating system, you may take the following steps to see what type of graphics card is installed in your computer.
- select the "start" button in the bottom left hand of your display
- select "run"
- type in "devmgmt.msc" (without the quotes)
- expand the file entitled "device adapters" and your graphics card will be listed
You have three options for letting World Community Grid use your graphics card:
- Do not let World Community Grid use your graphics card (this is the default option)
- Only let World Community Grid use your graphics card when you are not using your computer (you may set this either on the My Projects page or on the Device Profile page)
- Let World Community Grid use your graphics card all the time (you can set this option for a specific profile on the Device Profile page under the custom options section)
We encourage you to try the various options and select the option that best meets the requirements of your computing environment.
By default, World Community Grid will not use your graphics card. You will need to enable the option to allow World Community Grid to use your graphics card. This option is available on either the My Projects page or on the Device Profile page. This option is labeled 'If my computer can process work on my graphics card, then please send me work to run on my graphics card for the projects that I have selected above.' A member may check or uncheck this option.
Once you have allowed World Community Grid to utilize your graphics card, we only use your graphics card while you are not actively using your computer.
If you want World Community Grid to use your graphics card all the time, you must enable this option. This option is available on the Device Profile page under the custom options section. This option is labeled "Do work on my graphics card while computer is in use?". A member may select either "yes" or "no".
Yes. There are separate and independent settings for World Community Grid to run on either your CPU or on your graphics card.
By default, World Community Grid is set up to only run work using your CPU and not on your graphics card. The CPU preference is available on the Device Profile page under the custom options section. This option is labeled 'Allow research to run on my CPU?'. A member may select either "yes" or "no".
If you want World Community Grid to run on your graphics card. This option is available on the My Projects page or on the Device Profile page. This option is labeled 'If my computer can process work on my graphics card, then please send me work to run on my graphics card for the projects that I have selected above.' A member may check or uncheck this option. Please note that currently only the Help Conquer Cancer project has work units available for graphics card processing.
Yes. In order to do this, you have to use the <exclude_gpu> tag in the cc_config.xml file and be using the latest version of the BOINC client from Berkeley. This is outlined here. Please note that this is only possible with version 7.0 of the BOINC client and higher.
Yes. In order to do this, you have to use the <use_all_gpus> tag in the cc_config.xml file. Instructions to do this are available here.
Due to the nature of running research applications, it is possible that running World Community Grid on your graphics card while you are using your computer could interfere with the normal use of your computer. If you encounter this, then we suggest that you try the option to only allow World Community Grid to use your graphics card when you are not actively using your computer. This option is available on the Device Profile page under the custom options section. This option is labeled "Do work on my graphics card while computer is in use?". Select "no" and save.
World Community Grid has tested running research on graphics cards on BOINC version 6.10 and higher.
World Community Grid will award run time based on the elapsed time from when a work unit is started and when it finishes running. Credit and result counts will be awarded in the same manner as CPU participation.
No. Your contributions utilizing your graphics card will contribute to a specific research project and count towards earning a badge for that project.
General purpose computing on a graphics card is not an automatic transition and requires modifications and optimizations to the underlying algorithms of an application to realize performance increases. In addition, not all algorithms are well suited to general purpose computing on a graphics card and may not receive performance improvements.
We will work with the research scientists to make projects available on graphics cards if feasible and applicable to advancing the science application. However, it is up to the research scientists to enable their application to utilize graphics card technology.
Does the graphics card application include a graphic screen saver showing what is running?
No. The graphics card application does not include a screen saver. If you have selected to run work units on your graphics card, which is the primary display card, we recommend that you select the least intensive screen saver available, such as the "blank" screen saver option.
