Title: "Analysis of HIV Wild-Type and Mutant Structures via in Silico Docking against Diverse Ligand Libraries"
Abstract:
The FightAIDS@Home distributed computing project uses AutoDock for an initial virtual screen of HIV protease structures against a broad range of 1771 ligands including both known protease inhibitors and a diverse library of other ligands. The volume of results allows novel large-scale analyses of binding energy “profiles” for HIV structures. Beyond identifying potential lead compounds, these characterizations provide methods for choosing representative wild-type and mutant protein structures from the larger set. From the binding energy profiles of the PDB structures, a principal component analysis based analysis identifies seven “spanning” proteases. A complementary analysis finds that the wild-type protease structure 2BPZ best captures the central tendency of the protease set. Using a comparison of known protease inhibitors against the diverse ligand set yields an AutoDock binding energy “significance” threshold of −7.0 kcal/mol between significant, strongly binding ligands and other weak/nonspecific binding energies. This threshold captures nearly 98% of known inhibitor interactions while rejecting more than 95% of suspected noninhibitor interactions. These methods should be of general use in virtual screening projects and will be used to improve further FightAIDS@Home experiments.
To review the paper, please click here.
