We have addressed several defects and issues with the new website design that you brought to our attention. Thanks for your feedback!
- In the Forums, wide signatures were distorting the display of the conversation thread. Wide images in member signatures will now be scaled to fit and multiple images will wrap onto multiple lines if they exceed the column width.
- As you navigate between Forums and the rest of the site, we corrected the display of your login status.
- On the Download page, we updated the list of currently supported operating systems and corrected a broken link within the Windows installation instructions.
- On the Result Status page, we addresed several formatting issues.
- We fixed a navigation issue within the Device Manager section.
- We corrected popup windows on several pages which were using the old website design.
